there is a Civil 3D Forum post of someone interested in copying a surface Property Set to a Solid Property set…
https://forums.autodesk.com/t5/civil-3d-forum/is-there-any-way-to-quot-export-quot-property-sets-from-tin/td-p/9118088
I came close to making it work semi automatic. I am just concerned with my graph because I kind of sorted the Property set Lists in a manual/static way. how can I sort the property sets to create an automatic match, no matter what the property names are? In other words, I don’t want to use the List.Reorder Node!
Thank you for any help in advance,
Copy Surface PS to Solid.dwg (1.4 MB) Copy Surface PS to Solid.dyn (27.0 KB)
Hi @marshmallow ,
Thanks for sharing the forum inquiry. Here’s how I will approach the filter method to replace the manual/static way (via List.Reorder). I will do it via List.SortByKey and List.FilterByBoolMask.
Also, I will make both property set same name with Handle.
Copy Surface PS to Solid_V1.dwg (1.4 MB) Copy Surface PS to Solid_V1.dyn (53.9 KB) Copy Surface PS to Solid_V2.dyn (55.6 KB)
See Guide Images below:
Cheers,
Jowenn
