Hi everyone!
I am currently searching for a solution to run Dynamo scripts remotely.
We set up a digital table to apply diverse analysis of a district model and to simulate the results. While doing so, analysis modules which are calculating the results, and the digital table are connected through a local server. We would like to process some analysis in Dynamo as well. To do so, we need to connect Dynamo and digital table through the local server.
So that, when the user click “run” button on the table, the Dynamo could process the relative analysis simultaneously at the backend.
I was wondering if is there any option or solution method to run the Dynamo remotely over the local server?
Many thanks in advance!
