Is it possible to transform a solid with Volume 0 into a Solid?
The solid that creates the opening in a wall?
I can retrieve the openings, but not the one from a family instance.
python script:
import sys
clr.AddReference("RevitAPI")
ope=UnwrapElement(IN[0])
opt = Options()
opt.IncludeNonVisibleObjects = True
def _sol(geo):
a=[]
geoSet = geo.get_Geometry(opt)
for g in geoSet:
if isinstance(g, Solid):
return g.ToProtoType()
if isinstance(g, GeometryInstance):
for gi in g.GetInstanceGeometry():
a.append(gi)
return a
OUT = [_sol(o) for o in ope]
Thank you in advance.
Sincerely,
christian.stan
Here’s an example by checking the GraphicsStyleId
of invisible lines
import sys
import System
clr.AddReference('RevitAPI')
assemblies = System.AppDomain.CurrentDomain.GetAssemblies()
dynamo_asm = next((a for a in assemblies if a.GetName().Name == 'DynamoCore'),None)
dynamo_version = str(dynamo_asm.GetName().Version)
dynamo_version = tuple(int(x) for x in dynamo_version.split("."))
print('dynamo_version', dynamo_version)
import itertools
def get_CutLinesOpenning(e):
lines = []
opt = Options()
geoSet = e.get_Geometry(opt)
for g in geoSet:
if isinstance(gi, Line):
if gi.GraphicsStyleId == ElementId.InvalidElementId:
# get horizontal Lines
vect = gi.ComputeDerivatives(0.5, True).BasisX
if abs(vect.Z) < 0.001:
lines.append(gi.ToProtoType())
opt.Dispose()
return lines
def compute_cutSolid(cutLines):
DSCutSolid = None
cutLines.sort(key = lambda x : x.StartPoint.Z, reverse = True)
for idx, (key_, group) in enumerate(itertools.groupby(cutLines, key = lambda x : round(x.StartPoint.Z, 2))):
if idx == 0:
top = key_
if dynamo_version >= (2,16,0):
top_loopCurve = DS.PolyCurve.ByJoinedCurves([x for x in group], 0.001, False, 0)
top_loopCurve = DS.PolyCurve.ByJoinedCurves([x for x in group])
# get bottom curves (iterate to the end) and compute solid
bottom = key_
try:
DSCutSolid = DS.Curve.ExtrudeAsSolid(top_loopCurve, Vector.ByCoordinates(0,0,-1), abs(top - bottom))
except Exception as ex:
print(ex)
return DSCutSolid
e = UnwrapElement(IN[0])
cutLines = get_CutLinesOpenning(e)
OUT = compute_cutSolid(cutLines)
Thank you very much for the suggested approach: start with lines and rebuild a solid (it’s a shame I can’t access it).
I’ve varied it, but it’s still your approach.
Thank you very much.
import sys
opt = Options()
def _sol(geo):
a=[]
for g in geoSet:
if isinstance(g, Autodesk.Revit.DB.Solid):
if isinstance(gi, Autodesk.Revit.DB.Line):
a.append(gi)
nivz=[x.Evaluate(0.5,True).Z for x in a]
ht_extrusion=(max(nivz)-min(nivz))*0.3048
a.sort(key = lambda x : x.Evaluate(0.5,True).Z, reverse = True)
b=a[0:4]
polycurv=DS.PolyCurve.ByJoinedCurves([b.ToProtoType() for b in b])
solidfamily=DS.Curve.ExtrudeAsSolid(polycurv , DS.Vector.ByCoordinates(0,0,-1.0) , ht_extrusion)
return solidfamily
Sincerely,
Christian.stan
