I am not sure why but when i am in the node workspace my curser becomes extreamly small unless i am hovering over the use level arrow in a node. If i pull my mouse to the library it gose back to a normal size. Is there a setting i can change this?
I haven’t seen/heard of this - can you record it in action?
The first is clear and as i said its hovering over the level button. I had to take a picute with my phone to even see the curser for when shrinks on me. I also circled it so it is more easily found.
Do you use any applications which modify the display of your mouse?
I do not and i am lost to why it gets so tiny. I already have problems finding where my curser is already as im running a two monitor set up. This is the only place it has problems as if i move it out of the workspace window it gose back to normal size. To add to the confusion if i switch to the geometry display window it flips back to normal size as well.
Can you do a screencast recording the actual ‘jump’ in cursor size? I’m thinking a hardware issue but I’d need to see where the change is occurring to know. Do any other programs react this way (specifically wondering about Revit dropdowns)?
4K display
My laptop does the same
This is a small vidio showing it in action. When it first shrinks it is because i clicked to interact with the space.
Can you confirm if you’re using a 4K monitor or not?
Yes l’m using 4k monitors
So is there a setting that needs to be changed or is it something that will be fixed in a future dynamo update? Also for referance i am using dynamo V2.0.26826
