I created a video to explain.
The slider is suppose to control the Y placement of the front arc.
http://www.screencast.com/t/1dtH3H8F
I also included the .dyn
Thanks a lot
Wow, nice bug . . . I can reproduce this easily, and it still reproduces in current development builds. We'll take a look.
Sorry here's the new .dyn with limitations
Quick note, it seems to go bezerk when adding the loft surface.
I've set minimum so that we couldn't get points on top of each other and if you change the values with only curves it works fine.
If you add the loft then it behave
