I created this simple graph to align several viewtitles at once based off the alignment on a selectable sheet. There are a couple issues I am having. The main issue is with the viewtitle selection itself. For example when I use the sheet selector to pick which sheet will be the template for the others to align their viewtitles to, it works till that point and aligns them. However, whenever I change that sheet to a different one, it deletes the viewport on that sheet from the project. The other question I have is the selection of all the viewports I want to align. Is there a better way to select specific sheets from the dynamo player? Right now I have to open the graph to select the sheets on the dropdown list selector.
Any help would be greatly appreciated!
