Quick question:
Is there any way to obtain duct that shoe/tap is attached to? Maybe there is a way
Hi Tomasz,
In short โYesโ there is a way .
Could you tell me where should I start? Iโ ve checked pretty much everything in Revit lookup and revitapi without success. Maybe connector origin?
Yes Connector origin. Extract the connectors origin then convert Ducts to Solid Geometry and then filter ducts intersects with points.
Thank you,
Iโll post solution a lil bit later.
No problem
Pls find attached solution. I changed family type name to โuโ just for filtering taps. I wonder if there is other way to do this without checking intersections.
SHOE.dyn (13.2 KB)
As I thought this solution is painfully slow.
Maybe there is sth in API to do this faster ?
