Sheet creating
I am facing an issue while creating sheets, and the following error is occurring. Please advise.
Sheet numbers must be unique, so you’ll have to look at your source data for the numbers and the existing sheet’s numbers and modify one or the other to prevent overlap in the combined set.
Hi @VijayS try create a “fake” number first, could maybe works
Thanks for the feedback but can’t work.
The list levels for Sheet Name and Sheet Number inputs should be the same, I think? Try flattening the Sheet Name input.
What can’t work? Note that no one can see what your current graph actually does as your screenshot is too zoomed out. Follow the instructions in this post on how to create an image of your workspace and you’ll get better help.
It is a prerequisite for each sheet number to be unique within the project or sheet set, so you’re going to get error messages if you don’t change the way you approach the problem.
Can you see my node? I think the list of numbers is not being accepted.
Flatten the sheet name list, or change the Input to @L2.
I have added both the sheet name and sheet number, then resolved.
