Hi I am looking solution how to clear shared parameter value,
problem is if I add shared parameter to space lets call it computer loads W and I type value 100 W… I make Space Tag show me cooling load and computer laod…so if value exist it will show ma only this on Tag…this is grat…
but problem is when I by mistake type some value to lets say shaft and then I can not completly clear it so zero will remain and then my tag will not show cooling load as value never existed but will show computer loads = 0…
I want to find out if we can clear number value as far as I know it is not possible
secondly could we use Dynamo delete all shared parameters from project then reinstert them again as this will clear all value and then I import all values again…I guess I could sort before export by room number so when pasting back will be some order…
I hope someone can help and advice on that,
Michal
