# Setting multiple block attribute values
**URL:** <https://forum.dynamobim.com/t/setting-multiple-block-attribute-values/81691>\
**Category:** Civil 3D\
**Created:** [October 2, 2022, 8:26pm UTC](https://forum.dynamobim.com/t/setting-multiple-block-attribute-values/81691 "2022-10-02T20:26:09Z")\
**Showing post:** 15
**Author:** ![gilberto.arechigaiba](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/gilberto.arechigaiba/32/204980_2.png) [@gilberto.arechigaiba](https://forum.dynamobim.com/u/gilberto.arechigaiba)\
**Post date:** [April 14, 2023, 1:41pm UTC](https://forum.dynamobim.com/t/setting-multiple-block-attribute-values/81691/15 "2023-04-14T13:41:06Z")
Amigo @EdwinG_HMV, srry for the delay, long story short is that Attributes Belongs to Block so Each Block that you insert needs a sublist of Attributes and each Attribute needs a sublist of Values, I let you an example, you will have read all the topic of list of list in dynamo Primer, make attention in lacing and levels topics, But as i said before Levels are the path to the dark side, good luck!!
 ![Set Attribute By Tag 3](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/2/6/260b53bc70f9fe9112c9b8b885a0b8a39cd8cc58.jpeg)
_[View the full topic](https://forum.dynamobim.com/t/setting-multiple-block-attribute-values/81691)._
