I am trying to build a script that corrects autocad files. Basically our clients expect lines, polylines, circles etc to be placed in layer “X”.
I thought id just grab all these elements like so:
And then just run all those items through a obj.setlayer node, but some drawings have more than half a million lines, which just freezes Dynamo indefinitely (i assume, stopped after waiting for half an hour) .
So then i tried to feed it into a python script, i thought id just grab the entire array and then run over it in batches so i dont fill the memory before comitting everything. But… Im getting an error in the basic version of the python script (that doesn’t deal with batching yet)
The code below gives the following error:
"No method matches given arguments for OnExit (<class 'Autodesk.Autocad.ApplicationServices.DocumentLock>, <class ‘type’>, <class ‘TypeError’>,<class ‘traceback’>)… line 40 (the line with t.commit()
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
objects = IN[0] # List of objects
layer_name = IN[1] # Layer name
changed_objects = []
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
for obj in objects:
if isinstance(obj, Autodesk.AutoCAD.DatabaseServices.Entity):
obj.Layer = layer_name
changed_objects.append(obj)
t.Commit()
OUT = changed_objects
type or paste code here
Can someone help me out with the error, or tell me there’s a better/faster way to change a bagillion object layers?
