Hi all!. I am trying to set windows with points. I tried to find the intersections of points with walls. Some walls are intersected by two points. I’m trying to find the ID of the walls that come to the points, but I can’t. Thanks.
^Hi @yaseminV2XL5 is it something hre you are after ?
Hi @sovitek. I take the points from the CAD file. First I need to find out which wall the window will be on.
arhh ok…but should be the same as my example…but cant help you without a sample dwg and rvt
