hi All. So I need to set the layout rule like below but the node is giving an error Asked to convert non convertible types. If you have the parameters below it should be correct yes?
Hi @technitutors ,
Check whether your inputs are of the correct type, i.e. a string objecttype for a “string” input.
Also, maybe flattening your Rebar lists helps.
