Hi Everyone!
I want to set elevation section view, but I can’t find node… I need your help!
Thanks in advance…
Maybe give it a try and see if you can get it first?
Hi @mzjensen ,
I can get it first, But for some reason, I want to change set elevation section view.
Hi @mzjensen ,
I have installed the latest version 4.1.4 of Camber. But I can’t find the node “Sectionview.GetFromCivilObject”, nor in the Toolkit.
Hi @JPS,
I believe there was an update to the Camber package that made it easier to convert many different objects to Camber Objects in a single node rather than a separate convert node for every type of object. The “Convert to Camber Object” node should get you what you need.
Exactly what I was going to say. Thanks @omar.g!
Hopefully the benefits of that change are clear.
