Here’s a simplified version of what i’m trying to do.
How do I replace “dog” with A (first letter in the sequence).
For some reason the sequence counts all the false values too.
I want the output to be cat, A, cat.
If we assume shortest lacing, there are three lists of data here:
["cat", "dog", "cat"]
["A", "B", "C"]
[False, True, False]
The first item is False (cat, A), the second item is True (dog, B), and the third item is False (cat, C).
The node is working as expected, but if you want “dog” to correspond to “A”, you will have to modify list2
to reflect this.
That would be very easy
But I’m going to assume you intend to do something more like this …
repDog.dyn (22.1 KB)
Ooo, that looks promising. I’ll try that and get back to you!
Thankyou.
