Hi All,
I’m working in a routine which works which gets the information from an Excel File.
I’m also working with Dyno plugin. Every time I press the script button (created with Dyno), I have to select the elements to work with and the search the Excel file in my computer.
I want to select the excel file only the first time, and do only the selection of the elements every time I run the script. (The path of the the Excel file won’t be erased with the RAM memory).
I’m using the UI from the Data-Shape package (by @Mostafa_El_Ayoubi) and it offers a default path to the excel file. The problem is that the default path will change for every proyect I’m working in.
Hope I explained my issue properly, and any suggestions will be very valuable.
Thanks in advance!
