I would like to select a section and to put it onto a new sheet.
I have tried this, but, I can’t find how to convert “section name” to “view”
Thank you for your answer. I have already tried this, but I would like to do this in revit by selecting the section and create automaticaly the sheet with the view I have selected.
I have find a solution but, I I select an other section, sheet’s name change and the second section comes on !!
This is because dynamo doesn’t recreate the sheet only changes the input variable (which in this case is view is placed). Close dynamo between runs, use a new node, or better yet use dynamo player.
