Hi
I´ve got a technical question.
I wish to create a script which creates cropped plans from a referenced file.
In my “normal” script i just select a room, and create a new plan with a cropped area around my room, but I can´t select any rooms from a referenced file, at least Springs Nodes “Current selection” does not show anything.
We try to work with a new file to create our wall elevations in a different file to save filesize in the main project file. For the wall elevations we also have to link around 300 dwg files which would flood the mainfile with “crap”
Did you maybe have the same problem / did you find a solution? Do you have a better workflow?
Kind regards,
Jannis
