# Section Views not vertical - Dynamo
**URL:** <https://forum.dynamobim.com/t/section-views-not-vertical-dynamo/69286>\
**Category:** Revit\
**Tags:** revit, excel, geometry, dynamo\
**Created:** [October 14, 2021, 9:11am UTC](https://forum.dynamobim.com/t/section-views-not-vertical-dynamo/69286 "2021-10-14T09:11:35Z")\
**Showing post:** 3
**Author:** ![c.poupin](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/c.poupin/32/89152_2.png) [@c.poupin](https://forum.dynamobim.com/u/c.poupin)\
**Post date:** [October 18, 2021, 10:38am UTC](https://forum.dynamobim.com/t/section-views-not-vertical-dynamo/69286/3 "2021-10-18T10:38:16Z")
@joelecam
read this topic, maybe it can help you
> [@Create section and rotate section in same script](https://forum.dynamobim.com/t/create-section-and-rotate-section-in-same-script/67592):
> I am building a dynamo script that creates multiple sections for a model group. One of the sections I want to rotate after it is created, in them same script. I use a SectionView.ByCoordinateSystemMinPointMaxPoint to create the sections and that works fine. But then I use a python script to rotate one of the sections and that won’t work. When I put the python script in a separate dynamo script it works fine. Can somebody help me with this problem? Extra inf…
_[View the full topic](https://forum.dynamobim.com/t/section-views-not-vertical-dynamo/69286)._
