This is my script, when i hit run it works and creates callOuts bus returns null at OUT. I cant fix this because i don’t know where is the bug.
thanks for help.
thanks for help.
Hello Luis,
This is expected. That particular API call is a void method. That means that it’s not supposed to return anything in the first place.
Thank you Dimitar i’ll remember it for future questions.
How can i get the callOuts that i’m making this way, without filtering all views from the begining? may I get the ids directly here?
After closing the transaction, you can loop through the views once more, get the callout id with "View.GetReferenceCallouts " and then convert the id to an element with “doc.GetElement()”.
It works fine, thank you
