HI all,
Currently using Dynamo 2.0.3
I am trying to re-create a script from the Aussie BIM Guru which can place tags in the current view, and am having issues.
I can create the script and it all seems to work. The issue is when I close and re-open the script. Once it is closed and the opened, it is full of errors. As far as i can see, it might be something to do with the All Viiew-Dependent Family Instances Of Category node.
When i first build the graph, its all OK, when i close and re-open it, the return is null.
All of the required tags and parameters are present in the file as i am using a test file and it works in the first instance.
What i cant work out is why it would work when you first build the script, but then come back with null once that script is saved, closed and re-opened? its a great script and can save my team a heap of time, but so far it is a one time use only
