Hi All,
I am facing an issue caused by the inability to run a script whilst in the family editing environment.
The Problem:
I’m working with an In-Place Mass family in which I’ve created 3 divided surfaces.
I then placed a number of instances of 1 Generic Model Adaptive family, hosted to the nodes of the divided surfaces.
My intention was to then leverage Dynamo to randomize the Family Types of the Adaptive Generic Model family to create something like the below.
The issue I had is that when I run my ‘randomizing’ script whilst editing the in place mass, it doesn’t actually run until I have clicked the Finish button. And when I run the script when in the normal project environment, it is not able to dig into the family and modify the elements within it.
I was able to achieve what I wanted by creating the divided surfaces within the In-Place Mass environment, then finishing the Mass. I then applied the Adaptive Generic Model families to the divided surfaces whilst in the normal project environment and then ran my script - which worked fine - or so I thought.
The issue is that I’m not happy with the density of the geometry, and so I’d like to make the output less dense. My first thought was to simply change the spacing of the U and V grids on the divided surfaces to reduce the density. However, because I placed the generic models within the project environment and not within the In-Place Mass environment, there appears to be no link/connection between the Adaptive Generic Model families and the divided surfaces. The Adaptive Generic Model families aren’t actually hosted to the divided surface nodes, and so when the U and V spacing of the divided surfaces are modified, the Generic Model Adaptive families do not update to reflect these changes.
Hope that all made sense?
As you can appreciate, it is not much use having the Divided Surfaces if the attached geometry doesn’t update with it…
Essentially I’m querying if there is a way to run a script while editing a family, or to have a script make changes within an in-place family when not editing it. Is there a known workaround for the issue I’m having?
Thanks in advance!
