lale
February 15, 2020, 3:05pm
1
Hello!
I’m asking if it’s possible to add rule in respect to the actual date.
I want to check and filter dates with the actual date of today. I can’t find something.
ICan someone help me?
For example i want to check the warranty end with the actual date. Is the warranty end reached or if there i any time left.
Regards
Lale
Kulkul
February 15, 2020, 4:37pm
2
Hi @lale
lale:
someone help me?
Welcome to Dynamo Forum!
Could you please be more specific. Possible to drop your data structure or relevant files?
DateTime.Now amd DateTime.Today nodes outputs the current time and date
They are in Input->DateTime
lale
February 16, 2020, 8:39am
4
I get all elements of “Brandmelder” and the parameter “Garantieende” (warranty end). Then i try to check if there is time life left.
Maybe i have to change the format of my parameter…
lale
February 16, 2020, 9:04am
5
i’ve changed the format but at the end i want to know if the actual date is later or earlier then the warranty end.
Does someone know it?
thanks in advance!
Use timespan.bydatedifference instead simply a greater than operator:
Convert to some number and than you can compare the elements.
If I remember correctly you can compare DateTime objects directly in python using standard operators like > or < …
Kulkul
February 16, 2020, 5:09pm
8
Hi @lale
As @Andreas_Dieckmann pointed, you can do this way in python:
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import datetime
def task(Rule_With_Actual_Date):
dt = datetime.datetime.strptime(Rule_With_Actual_Date, "%d.%m.%Y") <= datetime.datetime.now()
return dt
OUT = map(task,IN[0])
And if you prefer to stick with nodes:
lale
February 18, 2020, 12:16pm
10
Thank you all. I’ve solved this problem with the timespan. Change it to minutes and compare which one is negative. Then i create to lists with the true and false ones.
It was easier than i thought
