I will try to be clear but my English is unfortunately approximate…
I created a volume on Dynamo that I duplicated on points on a Z axis.
I would like these volumes to rotate relative to each other. For example, the first volume is aligned to the x-axis. A second volume, higher up, rotates 20 degrees. A third one rotates 20 degrees relative to the second one (i.e. 40 degrees relative to the x-axis) etc…
A bit like making a spiral staircase…
Is it possible or is it easier to do it with an adaptive component on Revit?
I hope I’ve been clear enough!
Thanks a lot
