Hello everyone,
I want to rotate the whole building project (including walls, floors, roof, ceilings, windows and doors) by angle along the Z-axis. I try to use some nodes, such as Geometry.Rotate, Rotate Family, etc, to finish the work, but it fails to rotate the whole building at the same time. Do you have some better ways to achieve the target? Thanks.
Kind regards
Hao
Is this something you can do with Rotate True North or Rotate Project North?
Thanks for your reply,
Rotate the project north, is a good way. Do you have some suggested nodes package to rotate the project north?
Kind regards
Hao
I’m not sure. I would just do it directly in Revit. Dynamo probably isn’t going to save you a lot of time unless you’re having to do this for multiple projects all at once.
