Rotate Import Instance
Is it possible to rotate an import instance? I’ve successfully moved several of them at them at the same time with the MoveByVector node, but I need to rotate them simultaneously as well. The import instances are DWG links. I am using the archilab Rotate Family node.
Rotate DWGs.dyn (69.2 KB)
the inputs must be at same level, try to add List.Create after Element.Id node and after Angle value before you input them to the rotation node
another thing, you don’t have to convert the angle to radian
