Hi! I want to create a roof by geometry and after I want to use “Attach Top/Base” in Revit for my walls.
I created a surface and I did a solid (with Surface.Thicken) but I tried to do a Roof with DirectShape.ByGeometry and with Springs.FamilyInstance.ByGeometry and it didn’t work.
Any ideas?? Thanks a lot!
I’m working with Dynamo 1.3.2 and with Revit 2017 in English.
Hi @ionti
How about attaching by Top Offset Value after creating Geometry using Springs.FamilyInstance.ByGeometry node?
Thanks @Kulkul for the idea!
But if I do that, “Top Offset” have only one value and the result is like the picture.
I want that my wall attach the top of the roof with the form of the roof…
Thanks anyway!
You need to select all walls and use Geometry.Distance to get top offset value and set the values back.
Hi @Kulkul
I did that (I think) only with one wall but the wall “Top Offset” is only a number. I want that the wall link up to the Roof.
I want that the top of the walls follow the Roof (the red line in the picture).
Thanks for your help!!
Could you drop here relevant rvt and dyn file.
Sure! Thank you! The Dynamo version is 1.3.2 and Revit 2017 in english.
200328_02.dyn (25.6 KB) 200328_02.rvt (3.2 MB)
