I would like to export doors data such as “from room number/name” and “to room number/name”, when I export the data, the fields are empty.
I think that these informations belong to Doors category, Am I right ? If not, can someone tell me which category I should use to get doors linked informations to rooms.
Thank you
Can you put a watch node onto the results of the “to room number/name” and “from room number/name” parameter values?
Kulkul
July 3, 2017, 3:47pm
#4
Make sure you activate room calculation point inside door family.
Check what KulKul said.
Also it could be that the parameter you’re pulling doesn’t exist or hasn’t been defined.
Wire a List.First node into the all elements of category node, then set a Element.Parameters node off of that, and finally a watch node off of that.
I’m sorry to answear so lately.
I think I have found a solution, people created a function to get the from-to room doors information.
Here is the link :
https://forums.autodesk.com/t5/revit-architecture-forum/door-tag-with-quot-from-room-quot-parameter/td-p/5858395
Tell me what do you think, I am going to try this solution.
I may have been not really clear about the problem I have encountered.
Thank you for the time you have spent helping me
