Hi all¡¡ I am testing the line width that Revit prints because in the program interface my drawings looks cool (with thin lines disabled and all the line style, lines width and so on well defined) but when I print it loose quality… compare the lines of Autocad and printing the same line width with Revit and I have detected that in Revit all the lines that are less than 0.09mm are printed with the same thickness, all are printed with 0.09mm…Has anyone check this error?? I have chek it using Illustrator, that shows the width of the line that is in the pdf.
I have print in pdf using in revit first the archi lab node and then do it manually, i don´t know if there is something wrong or what happens…
lines width.pdf (79.8 KB)
Thanks in advance¡¡
Javi
