Hello!
I look for some advice about how I can change and override the Revit’s Built-in window analytical construction and subsequently properties (red box) using dynamo.
in Revit (2018), in a window family, if you choose one window from analytical construction, then the analytical properties change, but are dimmed and cannot be customized.
Currently, the only available solution, is to change it within the Constructions.xml in the main Revit installation folder. However, I am interested in Dynamo’s potential to solve this issue.
Regards,
Arghavan
