This is almost certainly a dependency conflict with a JSON library.
Steps to confirm:
Restart your CPU
Launch Revit
Start a new model from the <none> template and select ‘imperial’ units
Launch Dynamo
Reproduce the issue the simplest way possible (i.e. place a node or open a graph)
Grab your Dynamo log from %appdata%\Dynamo\Dynamo Revit\3.6\logs (just get the latest log)
Read the log carefully, noting any warnings, errors, or otherwise concerning bits in that log. Usually there will be a note around “could not load library ___ due to a conflict with ___” or similar, which will (somewhere in the massive string of names) list out offending Revit add-ins or Dynamo packages which caused the problem. Disable those and see if that fixes the issue; if so you will need to get an update to get things working again.
If you can’t read the log or aren’t sure what the conflict is when you get into it, post it here and the community can help id what strings to pull.
There’s a few warnings mentioned, I can disable all the packages with potential compatability issues (Dynamo Timer, RIE, Crumple, Clockwork)
“2026-05-13 10:25:25Z : Clockwork for Dynamo 3.x 3.3.0 has an engine version of 2.12.1.11123,
it may not be compatible with this version of Dynamo due to .NET runtime changes.”
“2026-05-13 10:25:24Z : There already exists an AlsoKnownAs mapping for DSCoreNodesUI.Logic.If.
2026-05-13 10:25:24Z : System.InvalidOperationException:
2026-05-13 10:25:24Z : There already exists an AlsoKnownAs mapping for If.”
“2026-05-13 10:25:27Z : Inconsistent UniqueId for DynamoTimer View Extension view extension. This may result in unexpected Dynamo behavior.”
hmmm… not seeing anything. Can you post the Revit journal from the same session? Might also want to try renaming your packages folder (no packages or view extensions will load when you do, which will rule those out as a source).
A LOT of DLL conflicts showing in those Revit journals, some of which are more concerning than others. Searching the journal for conflicts with same preloaded module of version should give you the clues you need to start pulling threads.
Disable all your Revit add-ins and see if it continues to reproduce. If not, try enabling the Autodesk provided ones first, then the 3rd party ones second. Specifically looking at DAQS Assist which has a conflict in the JSON library and drofusRevitLink_Revit2026 which has… 30(?) conflicts. A previously loaded tool might be the root cause, but you’ll have to do some leg work to narrow it down and bulk disabling is the easiest path forward. Keep the packages unloaded for the time being too.
I’ve tried on different computer and different accounts and the issue was the same, then I tried on a third PC on my account and it works which is strange.
Ok this is wierd… you have clearly disabled add-ins which are still in the paths for Dynamo… PyRevit jumped out but I can’t say that’s the cause.
However at this point you’ve done all the standard troubleshooting so we need to move into a formal support ticket. Please start a case via the Autodesk account portal at manage.autodesk.com and one of my colleagues will reach out with next steps. Be sure to include the journals and logs here (ideally renamed so the relationship between journal and log can be found readily, but they can manage that later on so no stress if not).
