In my continued effort to up date Dynamo script that ran in 2018 but fail in 2019 Revit, I having trouble trying to get a check box parameter value set in a schedule. In 2018 I would set a yes value with a 1.
In 2019 I’m getting a cast object error:
Project parameter setup for the FT_Elec_RIT_BOX check box:
I tried using true with the error returning a bool issue. I then tried “1”, “Yes”, 1.0 and the ScheduleFilter.ByFieldTypeandValue passed the schedule to the ScheduleView.AddFilter Node but threw an error in the ScheduleView.AddFilter saying that the value didn’t match the FT_Elec_RIT_BOX parameter type.
Anyone else running into this issue, if so what method did you use to over come it.
Thanks in advance Scott…
I forgot to mention I’m on Revit 2019.2 and Dynamo Core 2.0.3.8810.
