I am working to automate my code counts and have put a graph together that allows you to select rooms, annotation, and doors. Chews on each item and populate the tag depending on the values for each. Now, the problem is that I need to populate each tag with the same information, but it is derived from the door selection which may not be a list of the same length. So, I would like to know how / if I can get the value from say 1 door, then use it to populate say 3 annotations with the same information. currently it populates the first annotation, but then leaves the other blank.
