Hi
I am looking for a way to retrieve all instance parameter per group for example i want to show the parameter that under group Data only as picture below.
thank you
Hi
thank you
Use Sort.ByKey node connect parameter.string values to keys and parameters list to list. It will sort paramters per group.
I will try it right a way thank you man
it’s only showed with Revit 2017, not with 2015
