Running through CADLearning lesson.
Connected nodes with valid input… resting mouse over node does not show the output as lesson describes.
What am I doing wrong?
Yes… the bottom right I guess. (I’ll look at this again)
The CADLearning seems to say you can rest your mouse anywhere. But the version is old apparently.
Which Dynamo your using?
I am using the latest version… 2.0.1.5055
The version that CADLearning is using in the lesson… is older I am certain. Not nearly as many Nodes compared to what is in my Dynamo.
However, I just revisited this… don’t know what was wrong the other day… now I can rest my mouse anywhere on the Node and the result shows as CADLearning lesson says it should.
On question though… what is “No Replication Guide will be added” mean when I rest my mouse over the ‘Auto’ label in the lower right corner?.. and what is indicated by the ‘Auto’ label?
Never mind… should learn for my self… the Auto has to do with "Lacing’… which I do not understand yet.
I’m experiencing this issue now too- can’t see the results when hovering on a node. Any ideas on what may have fixed it for you?
Problem:
When using the + Operator, no output was being generated
Solution:
Context:
I had the same issue, where no output would show below the operator and the hover-text “no replication guide will be added”. Restarting Revit and reopening blank projects did not do anything to resolve the issue.
I tried drawing some walls in the blank project, and ta-da! The nodes are now working as they should be. Odd. Maybe this is a bug? A feature?
