Hello, I am alessio, an italian student of architecture (Sorry for the English, please forgive my mistakes). I am trying to insert some parametric surfaces into dynamo, but I have some problems with the replicator guides. I do not understand exactly how they work.
Here there is a file where the behaviour of the replicators is a bit strange. Perhaps I do not use the right method to do these things. In particular in the third case, one needs to use the replicator always in couple “<1> and <2>”. ReplicatorBehaviour
Hi Alessio, replication guide can only be applied to a single function. For arithmetic binary operator like “+”, “-”, “*”, “/”, internally they are represented as a function which takes two parameters. So an expression like a + b + c actually contains two function calls. If you want to apply replication guide to it, you may need to break it down into subexpressions.
For example, you may rewrite “a<1> + b<2> + c<3>” to “(a<1> + b<2>)<1> + c<2>”.
