Hi guys
Iam trying to place adaptive panels from points by selecting three points from manual select in dynamo after completing one panel placement if i repeat the process the new panel appears but the old panel is delete…and i tried by keeping point values in excel but it also not working…to place the pannel i need to open and close the dynamo can anyone say how to complete the process …
Unfortunately that is how Dynamo is meant to act. It is to allow easy testing, without having to track and undo changes inbetween runs while testing.
If you are working in Revit 2017 or newer, you can use Dynamo Player, which does save the changes after each run.
