Hi All
I am trying to filter out the curved grids from a list of grids collected from a sheet.
I have defined a function that creates a boolean list that I think I can then use to mask the curved grids out of the list. I am, however, struggling to figure this step out.
Another way to remove the curved grids could be through the Filtered Element Collector, but I am unsure if this is possible.
My final goal is to develop ribbons so all needs to be python code.
Please see my code below.
Thanks for your help.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from itertools import islice
app = uiapp.Application
# INPUTS
# CODE
# Get Viewports on Sheet
all_viewports = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
# Get Views in the Viewports
all_views = []
for viewport in all_viewports:
viewId = viewport.ViewId
all_views.append(doc.GetElement(viewId))
# Remove non-plan views from List
all_views_clean = []
for view in all_views:
if not isinstance (view,(Autodesk.Revit.DB.ViewPlan)):
continue
if view.ViewType == ViewType.Legend:
continue
all_views_clean.append(view)
#Get Grids
grids = []
for view in all_views_clean:
grids.append(FilteredElementCollector(doc, view.Id).OfCategory(BuiltInCategory.OST_Grids).WhereElementIsNotElementType().ToElements())
#Define straight vs curved grid boolean function
def isCurved(grid):
bool = grid.IsCurved
return bool
gridBoolList = []
for grid in grids:
gridBoolList.append(list(map(isCurved,grid)))
Hi @bayowindapo,
I’m not sure if you’re hoping to be able to use this on a list of sheets and that is why you have a list structure as below for your grids in view:
But I proceeded with the understanding that this was intentional.
I simply looped over each nested list within the variable ‘grids’ and filtered the whole list using the IsCurved property and appended that to the straight_grids variable. See below:
# INPUTS
# CODE
all_views = []
continue
continue
#Get Grids
grids = []
straight_grids = []
for grid_list in grids:
straight_grids.append(list(filter(lambda x: x.IsCurved == False, grid_list)))
OUT = straight_grids
I think you may be right that you could do this with a smarter filtered element collector but I’m no expert with them I’ll leave that to @c.poupin .
(I also removed some libraries you were importing and didnt need ).
Hope this helps!
Ahh, thanks so much!
It looks like it works; I’ve never used the lambda function. I’ll read up.
You are somewhat correct. The intention is to use the script to dimension grids on a list of plan views on a sheet.
Yes, it would be great to know if all can be done in the collector. @c.poupin
Thanks again.
you can use Linq or Predicate, however Python filter or list comprehension works fine too
Example
Lovely, much more succinct!
Didn’t realise you could filter the collection itself, good to know!
Wow thanks!
Great solution. Will take a while for my brain to digest that. Haha.
Thanks again.
