# Rebar in Blended Column
**URL:** <https://forum.dynamobim.com/t/rebar-in-blended-column/21495>\
**Category:** Revit\
**Created:** [April 30, 2018, 1:46pm UTC](https://forum.dynamobim.com/t/rebar-in-blended-column/21495 "2018-04-30T13:46:26Z")\
**Showing post:** 5
**Author:** ![shefypattambi](https://avatars.discourse-cdn.com/v4/letter/s/3be4f8/32.png) [@shefypattambi](https://forum.dynamobim.com/u/shefypattambi)\
**Post date:** [May 4, 2018, 2:18pm UTC](https://forum.dynamobim.com/t/rebar-in-blended-column/21495/5 "2018-05-04T14:18:55Z")
Hi @Dieter_Vermeulen, @Maximilian_Thumfart1,
it got installed…I will try with the new package and let you know. meanwhile could you please have a look at this thread also; to suggest a solution?
> [@Stirrup Rebar Warning - The multiplicities of other interior knots must be at most degree -2](https://forum.dynamobim.com/t/stirrup-rebar-warning-the-multiplicities-of-other-interior-knots-must-be-at-most-degree-2/21599):
> Hi, I can create the vertical rebar as shown in the picture without any problem using the dynamo for rebar package. But once I tried to create the stirrup bar then the node is giving this warning as shown in the picture. Any idea to resolve that ? PS: The curve for this stirrup bar is an idealised curve. Here is my graph [DynamoRebar- Single.dyn](https://forum.dynamobim.com/uploads/short-url/neCwGJgtcou4yg9gxSOvOa3uJg8.dyn) (133.1 KB) Here is my Revit Test File [https://drive.google.com/drive/folders/1dkrtwvvCB\_3USqVHnUUcZ2x13UQBtMLj?usp=sharing](https://drive.google.com/drive/folders/1dkrtwvvCB_3USqVHnUUcZ2x13UQBtMLj?usp=sharing)
_[View the full topic](https://forum.dynamobim.com/t/rebar-in-blended-column/21495)._
