I have a large set of detail component families which need elements moved from one subcategory to another. I thought it would be a fairly simple script, since I can create geometry and assign it to a subcategory, but I’m getting odd results in the detail component editing environment.
At first i tried using Element.SetParameterByName and got a variety of errors, each indicating I was feeding the wrong type of data into the node.
I then did some searching, and found that clockwork used to have a set subcategory node:
So I played with that code and again got a variety of error messages all of which indicated I was doing something wrong on a basic level. Did some digging and found that it had been lost along the way, so my guess was that it hadn’t been moved along with a good reason.
So as a last resort I tried grouping the IDs of elements with the bad line styles and sending them to the clipboard so I could paste all of the element IDs for the bad subcategory into a select by ID box and I get an error that these elements can’t be selected. Any ideas?
I retired this node at some point - if I remember correctly it was because of some changes in the way that Dynamo was handling categories after the 0.7 update. I actually have an open task to overhaul all of Clockwork’s subcategory-related nodes and this node is the only one I hadn’t done yet:
