are ramps exposed in the revit api? if yes, where, I dont find it…
thanks in advance
What do you need to do with ramps?
I am creating a railing in an inclinated slope and I need a host element, in this case a ramp, not an stair. It needs to be developed with the Revit api, so it works outside dynamo as well.
Hi @perezmartinezIgn and welcome, it should be fairly easy since it requires an element Id for the host , in your case a ramp element, take a look at the api docs:
It has an example at the bottom as well.
thanks for your comment @Elie.Trad,
I want to generate the ramp with the revit api, not only the railing, and this ramp generation with the revit api is the issue.
@perezmartinezIgn in this case I guess no it is not, did you consider using a floor element instead?
Why not using inclined floor as a host instead of a ramp?
