Hello All,
I have a question about setting ‘Apparent load calculation method’ with Python. The CircuitLoadCalculationMethod property in ElectricalSetting class has two values:
CircuitLoadCalculationMethod Property:
http://www.revitapidocs.com/2017.1/2554ffbc-6e19-677a-cd3a-a267d2664d10.htm
CircuitLoadCalculationMethod Enumeration:
http://www.revitapidocs.com/2017.1/d3ce255f-f1a1-7b52-a48c-320314213632.htm
In my code I have this:
s1 = CircuitLoadCalculationMethod.SumTrueLoadAndReactiveLoad // This returns ‘SumTrueLoadAndReactiveLoad’
s2 = CircuitLoadCalculationMethod.SumApparentLoad // This returns ‘SumApparentLoad’
i1 = int(CircuitLoadCalculationMethod.SumTrueLoadAndReactiveLoad) // This returns ‘0’
i2 = int(CircuitLoadCalculationMethod.SumApparentLoad) // This returns ‘1’
With the above, I think I am getting one step closer if I can set CircuitLoadCalculationMethod to ‘i1’ or ‘i2’ (or maybe ‘0’ or ‘1’). When I do this in Python:
ElectricalSetting.CircuitLoadCalculationMethod.Set(i2) // This return an error: AttributeError: ‘getset_descriptor’ object has no attribute ‘Set’
ElectricalSetting.CircuitLoadCalculationMethod.Get() // This return an error: AttributeError: ‘getset_descriptor’ object has no attribute ‘Get’
Okay, then I tried:
ElectricalSetting.CircuitLoadCalculationMethod.SetValue(1) // TypeError: SetValue() takes exactly 2 arguments (1 given)
I am not sure what the second arguments it is looking for. I surely don’t know how to SetValue a enum. Appreciate your help on this!
It is expecting the following two arguments:
-ElectricalSetting (of your document)
-CircuitLoadCalculationMethod (which will be the new value)
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Electrical import *
settings = doc.Settings.ElectricalSetting
settings_method = settings.CircuitLoadCalculationMethod
load_true = CircuitLoadCalculationMethod.SumTrueLoadAndReactiveLoad
load_apparent = CircuitLoadCalculationMethod.SumApparentLoad
TransactionManager.Instance.EnsureInTransaction(doc) # Begin Revit document transaction
ElectricalSetting.CircuitLoadCalculationMethod.SetValue(settings, load_apparent)
TransactionManager.Instance.TransactionTaskDone() # End Revit document transaction
A bit of an explanation of what’s happening here…
In your above lines, casting these CircuitLoadCalculationMethod members to integers will return their respective values. Even if you passed the document as the first argument and 1
as the second, it would raise the following error:
Rather than setting the CircuitLoadCalculationMethod to an integer, you have to set it to an actual CircuitLoadCalculationMethod.
Hi Christian,
Thank you for your detail explanation. Your suggested solution works perfectly in my case. Appreciate you big help on this. You really saved my day!
Kevin
