Hi All
This workflow was working a few moths ago .
I was opening and closing files from Desktop Connector to force them syncing.
Python code below.
`file = open(path,“r”)
file.close()`
It doesn’t work anymore. Something changed in desktop connector (I’m using 14.11.0.1476) ?
Any other way to achieve that ?
Thanks!
Should work - what is the error you are getting? Note that the paths changed somewhere around v12 to incorporate the change from BIM360 to Autodesk Docs.
@jacob.small there is no error. I have the code in a try-except block and the open file is executed. I have the correct new path. They file in the desktop connector is not synced though.
I am unable to reproduce… might be a cloud side delay or a concurrent access issue.
Can you force sync in DTX?
It may be worth looking into the API options.
It works if I manually double click on the file.
So it’s working on your end using Python ? The file goes from Online to Synced ?
what API options ?
Yes - that method is working for me (and as far as I know others as well).
The application has an API which I have popped open to do some stuff. There is no documentation, ensured or implied stability or consistency with it so it’s a bit of a dig to make it work.
Greetings,
Im having this issue as well. Did you have any luck getting the file to sync with python?
