How to set "Disallow Join" for Structural Framing using Python?
hello all,
i have a lot of structural framings and they all need to be at the end ‘disallowed join’. So when i have to do this by hand it is killing for my brain.
i’ve read some posts that it is possible in Python. Does some one have the code for this? I’ve really no idea where to start.
Also, where do i start if i want to do this my self? I’ve a link here about all kind of revit api docs, but how do i use it in Python?
http://www.revitapidocs.com/2017/6ea65e8b-45f6-afc6-ec04-de60fc248f17.htm
try if this helps
You can read abot clr and references here: Dividing parts with dynamo
clr.AddReference('RevitAPI')
#Unwrapping Dynamoelement to Revit element.
beams = UnwrapElement(IN[0])
for beam in beams:
	StructuralFramingUtils.DisallowJoinAtEnd(beam,0)
	StructuralFramingUtils.DisallowJoinAtEnd(beam,1)
OUT = 0
great, it totally worked! Thanks a lot
i just needed to set the lacing on longest
thnx, this is what i was looking for.
check this code:
# Import RevitAPI
clr.AddReference("RevitAPI")
# Unwrap
input = UnwrapElement( IN[0] )
elements = []
#force input into list
try:
    for e in input:
        if e.Category.Name == "Structural Framing":
            elements.append(e)
except:
    if input.Category.Name == "Structural Framing":
        elements.append(input)
# Start Transaction
for e in elements:
    Autodesk.Revit.DB.Structure.StructuralFramingUtils.DisallowJoinAtEnd(e, 0)
    Autodesk.Revit.DB.Structure.StructuralFramingUtils.DisallowJoinAtEnd(e, 1)
# End Transaction
# Wrap
OUT = elements
