I am trying to filter elements with a Python script. My aim is to use FilteredElementCollector with my own set of rules.
I am trying to use FilteredElementCollector.WherePasses(MYFILTERNAME) method, where MYFILTERNAME would be a custom filter that I defined.
I have successfully created ParameterFilterElement with my own rules, however when I use it for the Collector WherePasses() method I get the error that “expected ElementFilter, got ParameterFilterElement instead”, so I assume that I am using wrong kind of filter class here, but I really don’t know any other way to declare my rules.
Please find my python script:
import System
clr.AddReference("RevitAPI")
clr.AddReference("ProtoGeometry")
app = DocumentManager.Instance.CurrentUIApplication.Application
app = uiapp.Application
Parameter = BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS
rules = []
rules.append(ParameterFilterRuleFactory.CreateEqualsRule(ElementId(Parameter), "aaa", True))
WallsCat = IN[0]
CatList = []
for i in WallsCat:
CatList.append(ElementId(i.Id))
typedCatList = List[ElementId](CatList)
MyFilter = ParameterFilterElement.Create(doc, "MojFiltr", typedCatList, rules)
abc = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().WherePasses(MyFilter).ToElements()
OUT = abc
I believe ParameterFilterElement is the API method used for View Filters, not for FilteredElementCollectors. Try adjusting the filter portion of your script to this:
clr.AddReference('RevitAPI')
bip = BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS
provider = ParameterValueProvider(ElementId(bip))
evaluator = FilterStringEquals();
rule = FilterStringRule(provider, evaluator, "aaa", False);
filter = ElementParameterFilter(rule);
walls = FilteredElementCollector(doc).OfClass(Wall).WherePasses(filter).ToElements()
OUT = walls
Thank you a lot! It worked.
this got me thinking and I played with it a bit for a wall example
#refer to the building coder, forum & revitapidocs.com
#http://thebuildingcoder.typepad.com/blog/2010/06/parameter-filter.html
#https://forum.dynamobim.com/t/python-custom-rules-for-filteredelementcollector/21135/2?u=adam_bear1
#http://www.revitapidocs.com/2018.1/fb011c91-be7e-f737-28c7-3f1e1917a0e0.htm
#boilerplate
fec = FilteredElementCollector(doc)
#useful list of bip to copy paste from revitapidocs.com
#StringValues
'ALL_MODEL_DESCRIPTION'
'ALL_MODEL_MARK'
'ALL_MODEL_INSTANCE_COMMENTS'
'ALL_MODEL_TYPE_COMMENTS'
#ElementId
'ID_PARAM'
#Integers
'WALL_BOTTOM_IS_ATTACHED'
'WALL_TOP_IS_ATTACHED'
'WALL_ATTR_ROOM_BOUNDING'
'RELATED_TO_MASS'
'WALL_STRUCTURAL_SIGNIFICANT'
'STRUCTURAL_ANALYTICAL_MODEL'
#Doubles
'ALL_MODEL_COST'
enum = 'WALL_STRUCTURAL_SIGNIFICANT'
#define myclass, bip, provider
myclass = Wall
#bip = BuiltInParameter.WALL_STRUCTURAL_SIGNIFICANT
bip = eval('BuiltInParameter.' + enum)
#evaluate strings, elem id, integer, doubles
#evaluate string values
#test = 'aaa'
#evaluator = FilterStringContains()
#evaluator = FilterStringEquals()
#rule = FilterStringRule(provider, evaluator, test, False)
#evaluate element id
#evaluator = FilterNumericEquals()
#evaluator = FilterNumericGreater()
#test = ElementId(0)
#rule = FilterElementIdRule(provider, evaluator, test)
#evaluate integer values
test = 1
rule = FilterIntegerRule(provider, evaluator, test)
#evaluate double values
#test = 5.55
#rule = FilterDoubleRule(provider, evaluator, test, 10**-3)
#fec of class passing filter to elements
elems = fec.OfClass(myclass).WherePasses(filter).ToElements()
#output
OUT = elems
