Python: correct format on input to datagridview
I want to add rows to a datagridview “manually”. I tried converting the following code to python with reference to Manipulate Rows in the Windows Forms DataGridView Control and How to Build the User Interface.
However, I struggle with adding rows. The following doesn’t work:
for j in range(len(signals)):
    self._dataGridView1.Rows.Add(signals[j])
The following code does work, but is not dynamically enough as I don’t know how many elements there will be:
    self._dataGridView1.Rows.Add(signals[j][0], signals[j][1], signals[j][2], signals[j][3])
How should I fix this? I tried tuple, but the result were a tuple with all the info shown in the first cell instead of spread over the columns.
I would not like to add packages, as this is to be run within revid dynamo among several users, and I cannot convince everyone to install packages.
full code for context:
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
clr.AddReference('System.Data')
from Autodesk.Revit.UI import TaskDialog
from System.Windows.Forms import *
from System.Drawing import (
    Point, Size,
    Font, FontStyle,
    GraphicsUnit
from System.Data import DataSet
from System.Data.Odbc import OdbcConnection, OdbcDataAdapter
msgBox = TaskDialog
headers = IN[0]
signals = IN[1]
class DataGridViewQueryForm(Form):
        def __init__(self):
            self.Text = 'Signals'
            self.ClientSize = Size(942, 255)
            self.MinimumSize = Size(500, 200)
            self.setupDataGridView()
        def setupDataGridView(self):
            self._dataGridView1 = DataGridView()
            self._dataGridView1.AllowUserToOrderColumns = True
            self._dataGridView1.ColumnHeadersHeightSizeMode = DataGridViewColumnHeadersHeightSizeMode.AutoSize
            self._dataGridView1.Dock = DockStyle.Fill
            self._dataGridView1.Location = Point(0, 111)
            self._dataGridView1.Size = Size(506, 273)
            self._dataGridView1.TabIndex = 3
            self._dataGridView1.ColumnCount = len(headers)
            self._dataGridView1.ColumnHeadersVisible = True
            for i in range(len(headers)):
                self._dataGridView1.Columns[i].Name = headers[i]
            self.Controls.Add(self._dataGridView1)
Application.Run(DataGridViewQueryForm())
@TejaswiniUL Can you show you graph as well?
Yeah, Figured it out.
Had to use System.Array.
from System import Array
code changes:
array_str = Array.CreateInstance(str, len(headers))
        for k in range(len(headers)):
            array_str[k] = signals[j][k]
        self._dataGridView1.Rows.Add(array_str)
just a hint, using range is not pytonic. Python has some very good functions to traverse lists.
ex. for item in headers: will do it. If you need an index, then try for idx, item in enumerate(headers): in your case where you have a double forloop and dont need the item, then try this.
for idx_col, _ in enumerate(signals):
    for idx_row, _ in enumerate(headers):
        array_str[idx_row] = signals[idxCol][idx_row]
It could be even more efficient, but let that be for now :slight_smile:
Sure, Thank you @erfajo
