Python Autodesk.Revit.DB.Viewplan.Create Custom ViewFamilyType Error
A very big thank you to @alvpickmans foor the solution to this post. find it here:
https://forum.dynamobim.com/t/python-autodesk-revit-db-viewplan-create/22209/6
Here is the code:
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitNodes") # Import RevitNodes
from Revit.Elements import * # Import Revit elements
clr.AddReference("RevitServices") # Import DocumentManager
clr.AddReference('RevitAPI') #import clr
from Autodesk.Revit.DB import * # Import ToDSType(bool) extension method
import System # Import System
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
prjViewFamilyTypes = IN[0] # ALL THE FAMILY TYPES IN THE PROJECT
xlsxViewFamilyTypeNames = IN[1] # CUSTOM VIEW TYPES THAT WERE CREATED FOR THE RPOJECT
xlsxSheetNumberDiscipline = IN[2] # THE DISCIPLINE CODE IN THE SHEET NAMES
xlsxSheetName = IN[3] # ALL THE SHEET NAMES THAT MUST BE CREATED FOR EACH LEVEL
xlsxLevels = IN[4] # ALL THE LEVELS THAT WERE CREATED FOR THIS PROJECT
Titleblock = IN[5] # THE TITLEBLOCK FAMILY TYPE THAT NEEDS TO BE USED TO CREATE THE SHEET
prjLevels = IN[6] # ALL THE LEVELS IN THE PROJECT
SheetList = [] # CONTATINER FOR THE SHEETS THAT ARE CREATED
app = uiapp.Application
Discipline =[]
name = "PD - DRAINAGE - BELOW"
viewFamilyTypes = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
id = -1
for viewType in viewFamilyTypes:
	typeName = viewType.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString()
	if typeName == name:
		id = viewType.Id
		break
TransactionManager.Instance.EnsureInTransaction(doc) # you need an active transaction as you will create elements
ViewFamilyTypeId = ElementId(prjViewFamilyTypes[0].Id)
# ViewFamilyTypeId = ElementId(prjViewFamilyTypes[10].Id)       THIS DOES NOT WORK!
LevelId = ElementId(prjLevels[0].Id)
newViewPlan = ViewPlan.Create(doc, id, LevelId)
#newViewPlan = ViewPlan.Create(doc, ViewFamilyTypeId, LevelId)
newViewPlan.Name = "2"
OUT = Discipline
