Purge Unused Scope Boxes
Trying to sort unused scope boxes in order to delete them. No Luck however as is the parameter node returns error:
@Tim.r
you have to delete the view
i would do like x.Name → string.contains → certainName → Element.delete
KR
Andreas
I think I am not undersating, I want to delete the scope box that is not used. Are you saying I have to delete the view ?
We can’t tell you what’s going on if you don’t show the node data. Please make sure you pin all node preview bubbles when sharing an image.
You probably have nulls in your view list. This is usually from 3D view templates. You should just need to filter them out.
From what I can tell, it may be related to instance parameter, but I could be wrong:
You’re filtering the view name instead of the view. Make sure you’re passing the actual view element onto the filter.
Pretty sure the crumple package has some nodes for scope box is in use etc etc…
Isnt this just for simply quering the model of scope box use: I tried it no luck:
The node itself gives a bool, so filter the list of scopeboxes put into it like so.
Thank you PyXam, it all worked! :smiley:
