My question as a simulation is as follows: Suppose there is a project on my home
machines, all built in concrete and glass windows with some ray-ban. with the following
measures: length = 120 feet x 41 feet x width = height = 30 feet. and internally consists
of a thermal power HVAC equipment installed with the following: Two 750 Ton
Centrifugal., 02 Chiller 250 Ton., 02 Hot water boilers., 16 pumps cold water., 16
Pumps condensate. In this example it is possible to calculate the thermal load
generated within the enclosure and show the entire mass of the systems intalled such as equipment, pipes, fittings, electrical panels, cables Bandela among others. All through the Vasari Project.
Graciously
lcchvacr_Mep projects
Hi Luiz,
Vasari is intended as an early stage energy analysis application and the conditions you are describing are of a more detailed nature. For your example, Vasari could help by looking at issues like, “are my fuel costs lower with 30% glazing or 40%”, “do I get significant return on a highly insulated concrete shell versus a moderate one?”
