Looking to who are already using 2.0. None of my pre-2.0 graphs will open with Dynamo 2.0. Is this to be expected? Or did I miss something on the installation.
Ben
Ben
What kind of workflows are they? Are there a lot of custom nodes in use?
Thanks @john_pierson for getting back with me.
It is literally everything. Some with some with all OOTB, some with all custom nodes but the majority with a combination of both.
If I select one of the example files, many of the nodes are not recognized.
If I search for the missing node (Number or Watch) and try to add it to the canvas, Dynamo will not let me.
The samples are the ONLY .dyn files I can open. Anything else just opens a blank Home.dyn screen.
Here is a sample graph that opens in 1.3.3, but not in 2.0
Attached is the original file.
ChangeViewTitleToSheetNumAndDetNum.dyn (31.9 KB)
Thanks for the help
Ben
@BenDoty_LMN please file this on our GitHub issue page:
please provide samples of files that work and those that do not with all necessary dependencies to run them.
it appears that even the sample file above opens in a strange state… which may point to a bad installation.
Run th FixIt tool to clean out the bad install when this happens. Make sure you’re pulling all dynamo stuff off the system.
@BenDoty_LMN An issue has been filed here: https://github.com/DynamoDS/Dynamo/issues/8770
Please add more details on github, if possible.
Specifically, can you please provide the following:
We suspect this is unique to your setup and likely a Dynamo installation issue.
@Racel thanks for the update. I uninstalled Dynamo 1.3, 2.0 and Studio, then reinstalled and 2.0 graphs are opening fine now.
